Vacuum bag for double sides and laminated solid lining
http://www-.luthiersforum.com/forum/viewtopic.php?f=10101&t=56856
Author:  bcombs510 [ Wed Oct 30, 2024 9:02 am ]
Post subject:  Vacuum bag for double sides and laminated solid lining
Hey folks,
In the last roundtable we talked about double sides, solid lining & vacuum bags. Here is a couple short videos showing making and then installing solid lining. Hope it’s useful.
https://youtu.be/FrWOZYaufd4?si=_fZsg5NfXNdVsqs6
https://youtube.com/shorts/1hX_2emssRs? ... SBIAKlQZfF
Brad
Author:  bobgramann [ Wed Oct 30, 2024 12:06 pm ]
Post subject:  Re: Vacuum bag for double sides and laminated solid lining
Thank you, Brad. That makes perfect sense. I even thought I smelled the epoxy in the first video.
Author:  bionta [ Wed Oct 30, 2024 2:27 pm ]
Very cool, Brad! Thanks for making this video.
Author:  Terence Kennedy [ Wed Oct 30, 2024 6:38 pm ]
Cool, I use clamping cauls but otherwise pretty similar. I usually leave clamped for at least 12 hrs. Do you leave the vacuum pump running that long?
With the solid linings that is an extremely rigid rimset. I have noticed that while increased mass/stiffness definitely increases volume too much can affect tone in a negative way. Have you seen a similar correlation?
Author:  bcombs510 [ Wed Oct 30, 2024 6:56 pm ]
The pump I have uses a reservoir and kicks off once it pulls the vacuum. It cycles once every few hours. I typically leave it for 8 hours / overnight.
I haven’t noticed an issue with too much volume on the latest 00 builds, but it’s been awhile since I’ve built a dred so will report back.
